This carb is on a McCullogh 3200 Chainsaw. The saw will start if I hold the throttle wide open. Once started I try to adjust the high speed needle. I have to close the needle to get the saw to run good. The carb is obviously over fueling. Can this be a float level set to high? What other things could cause this problem? I have dissasembled the carb and put a new gasket kit in. I checked the float level when it was open, It checked ok.
Thanks for any help.
