The Traxxas EZ-Peak Plus is a 6-amp, fully-programmable, AC/DC charger designed for fast and easy charging of LiPo, LiFe, LiIon, NiMH, NiCd, and even lead-acid battery packs. Sophisticated peak-detection technology with Fast Charge, Balance Charge and Storage modes assure peak performance from high-performance lithium batteries. A large, backlit LCD screen and simple four-button interface makes it easy to select charge modes and program the EZ-Peak Plus. Five Charge Profiles customized for Traxxas NiMH and LiPo packs are pre-installed, and can be edited to suit individual needs and preferences. Charge a variety of battery types, without re-programming, just select your profile and go. The included JST/XH balance board allows the cells in LiPo packs to be charged and discharged individually, assuring maximum capacity, power, performance, and cycle life.
The optional Dual Charging adapter, available for 2S packs and 3S packs, allows two Power Cell LiPo battery packs to be balance-charged simultaneously for even greater charging convenience.
EZ-Peak Plus Features
- Traxxas, Molex, and RX charge leads included
- Standard XH Balance Board
- Charges at up to 6 amps
- Backlit LCD display
- Integrated cooling fan
- Compatible with LiPo, LiIon, LiFe, NiMH, NiCD, and even lead-acid batteries
- Charges 1-6 cell LiPo, 1-15 cell NiMH
- Unique “Storage” mode charges LiPo packs to 50% capacity for storage
- Built-in 2amp discharger with programmable cycling
- Programmable Safety Timer and Capacity Cut-Off
- 5 Editable Charge Profiles
- Reverse-polarity, short-circuit, and thermal overload protection
- Optional Temperature Sensor
- Optional Dual Charging adapters permit two packs to be charged simultaneously
- Traxxas Lifetime Electronics Warranty
Source: Traxxas [traxxas.com]
More...
