1 - 18 of 18 Posts
You need to make a fixture to hold the can indexing on the magnets and use narrow zapper poles.
And yes Virginna, it is illigal in most places and should be in all, hard to catch this ones it done, but not impossible, just need a gig to mount the flux meter in.
I don't know anything about needing narrow zapper poles.
I was told to take out of the back of the magnet.
Then, zap the hole magnet head on to correct the magnetic flux.
I don't run spec class but I do zap my motor magnets to bring them
back to new after a nice cut on the com. :thumbsup:
Its really very easy to tech. If you look in the vent holes on the side of a can you can see the arm in there. Look for the drill balance slot to stop (every other stop) in the center of those holes. If they dont the magnets have been advanced. Big Jim and JB (Arcor) came up with this method and it works easy.
EA
battery zapper
hey guys!! my Question is can you used a battery zapper on the 4200s? like the( XIPP 3300) and would that help or hurt the batterys and why? I have heard some guys talking about useing them. any info would be appreciated thank you. :thumbsup:
Advancing the magetic timing is cheating, plain and simple. No grey area. When a class has a set timing, like Stock at 24 degrees, 19T at 36 degrees or Spec at 12 degrees, changing the degrees is cheating, no matter how it's done. In ARCOR, this is known as the "Big Jim Rule", in honor to one of the best motor man to ever live. May God Bless Him. :)
EA
this method is very reliable and really does work :thumbsup:
HobbyTalk Pro
What about cryo-treating ?
Cryogenics can work wonders for magnets. The increased molecular alignment can really enhance / maximize the magnets strength and also make the entire magnet more uniform - no portion weaker or stonger than another.
It is a lengthy process, and you need to work with a cryogenist that has knowledge of magnets. Then you need a really strong magnetizer to remagnetize the magnet once you get it back from, not the small units you see at the tracks - as these are not nearly strong enough.
It is a bit of leg work, but does yield results.
holy hot tub time machine!
the year is 2010
we run lipo and brushless
step away from the parachute pants and the twister lathe!
of course it would be me! i was hoping they were talking about a bug zapper..getting close to skeeter season in florida
1 - 18 of 18 Posts
