1 - 1 of 1 Posts
*Click the image to buy
The brand new Yeah Racing Banana Plug 4000mAh 7.4V Li-Po Battery available now @ rcMart.com
Yeah Racing have released a banana plug version of the existing 4000mAh 7.4V Li-Po Battery. This banana plug version battery (#LP-0045) has been improved by adding several new features such as banana female plug, balance charge plug and new case design.
Description:
This new li-po battery (LP-0045) is specifically developed for all 1/10 explosive RC cars. It makes the cars perform speedy! Most of the RC drivers comment it is a MUST buy item especially for the competition! The process of installation is very simple and time-saving which applies to all RC cars. Just strengthen your car with this powerful li-po battery!
Features:
# For: 1/10 RC Car
# 2 x Banana female plug
# Balance discharge plug
# New design hard case
# Bumps attached at the bottom of the case to provide perfect fitment on wide range of chassis
Specification:
# Discharge rate: 25C
# Capacity:4000mAh
# Voltage:7.4v
# Length: 135mm
# Width: 45mm
# Height: 23mm (includes bumps)
Why go Li-Po?
# Runtime up to 30% longer than traditional NiMH/NiCd (of the same capacity).
# Weight up to 40% lighter than traditional NiMH/NiCd (of the same capacity).
# Li-Po power delivery ensures maximum power throughout the discharge cycle.
# Less internal resistance offered by advanced cell fusion technology.
# Less energy lost in form of heat makes a greater power output.
# Complicated maintenance-free or conditioning-free.
# Balancing port included.
# Compatibles 90% of 1/10 scale chassis with little or zero modification.
# Can be used and recharged unlimited times per session.
# Less cost over time as longer lifespan up to 10 times that of NiMH/NiCd.
# Sealed case makes perfect for tracks looking.
Where to buy?
http://www.rcmart.com/catalog/rc-ba...ipo-pack-4000mah-with-case-banan-p-29632.html
1 - 1 of 1 Posts
