*Click the image to buy.
A new arrival product - The Xevo (#PID29808) FF conversion kit for Tamiya M03/M04/M05 is now available @ rcMart.com
Description:
With this conversion kit you can convert your Tamiya M03/M04/M05 with front motor chassis to reduce front tire slip and enhance maximum mobility and traction. Come with Aluminum motor mount and used with pinion of gear from 19T to 26T.
Feature:
For: Tamiya M03/M04/M05
Material: Aluminum and Black FRP
Specification:
Wheelbase: 210/225mm
Pinion gear: from 19T to 26T
Length of suitable battery: max. 225mm
Include:
Xevo FF Conversion Kit for M03/M04/M05 (1set)
Additional Tamiya Parts Require:
SP797 5mm Adjuster (short) (1set)
OP640 5mm Aluminum Ball Nut (1set)
OP642 5mm Aluminum Ball Connector (1set)
OP267 Ball Differential (1set) (Not required if you use Gear Diff.)
OP1000 M Chassis Aluminum Damper Set (1set) OR, SP746 CVA Super Mini Shock Unit Set (2sets)
*Photos for reference only
where to buy?
http://www.rcmart.com/catalog/rc-tl01ff01ff02m03-xevo-conversion-p-29808.html
