1 - 2 of 2 Posts
I'm tring to rewire a 11 H.P. Briggs and Stratton with the only two toggle switches. not sur if it's possible not having much luck with wire combinatons. any suggestions?
Hello and Welcome to Hobby Talk.I'm not sure what you are trying to do.Is this engine on a lawn tractor and you are trying to bypass an ignition switch?Here is a link to a standard Briggs ignition switch setup.One toggle switch would go in line with the small wire on the starter solenoid for starting (push button switch would be better).The other toggle switch would go to the ignition coil and ground to kill the engine.
http://www.briggsandstratton.com-su...~-media-B19B3742DFDA4270B639EEA3818B7018.ashx
Hope this helps.
1 - 2 of 2 Posts
