1 - 20 of 30 Posts
WIP: The 'Junkster' Pod Racer
1. The 'Junkster' Pod Racer
I have started on another build taking another break from truck building, while gathering thoughts for my next one. I have several in mind but I am trying to figure out which one to choose and how to proceed. 'Till then, I am working on a pod racer. Yes, another one. For some reason I have a think for these machines. I also planning on a big spaceship build after this build. We'll see. Anyways, Here are pics of the progress so far. We will see how it turns out.
The concept of this build is simple. It is an older model that has been rebuilt from scrap using various metal and machine components, hence, the name, The 'Junkster'. So It is going to be weathered to show the old age and extensive usage. Fits me just right.
2. Most of you guys may already know what parts I am using here already. It's from a 1/32 F-15E fighter jet. I had no drawings, just planning as I build. I have lots of parts(lots), as you can see in the pics blow:
3. This will be the body of the engines. Or should I say the fuselage. As you can see, I've already started adding the details to it. Majority of the parts are taken from other kits. Makes things easy for me, as time is always of the essence.
Discussion Starter · #2 ·
Adding the small details. The small details makes the electro attachments(not sure what they are called. just going with the flow) come to life. Added some styrene in certain areas.
I'm going to add some bits and pieces at the rear of the fuselage, to make it look busy.
Added short oval shape styrene on both sides of the fuselage for a total of 6 short lengths.
Discussion Starter · #4 ·
Some more exterior detailing on the fuselage. Styrene stripping on the sides lading up to the front. Added parts from a missile at both front corner ends of the fuselage.
Added a couple details under the both sides of the fuselage. I will not be adding a lot of details on the bottom as it will not be easily visible for viewing anyway. I also think the amount of detail on the fuselage already as it is on the underside is just right and does not need too much attention.
Discussion Starter · #5 ·
These will be air and maintenance vent panels, which will be displayed open, to display some of the details inside. These are just the original F-15E doors that came with the original fighter plane, as you plane enthusiast might already know what I'm talking about.
I've already painted on of the panels to test how it will look.
These particular panel doors were taken from a stryker model. I seem to have lots of these parts lying around back when I was scratch building AFV models.
The braking flap. This will be left in the open position as to give the entire model character when it finally placed on its mounting baseboard.
Discussion Starter · #6 ·
8. Did some more detailing at the rear to cover up that flat piece of styrene I had added to fill the huge gap in the fuselage. Added some bits and pieces to make the rear end look busy enough to keep the viewer interested.
Discussion Starter · #7 ·
9. I had to find a way to conceal those two exhaust vents out the back without getting too intricate with the overall look. So I opted to add some sort of vent metal meshes then make some covers to cut direct view into the exhaust. So I came up with these two methods you see in the pics below.
These will be the vents angled downwards. I added a little mechanism to both sides to give the impression that the vents can be folded upwards at right angle for a horizontal exit.
The covers added:
Discussion Starter · #8 ·
10. I have already started working on the pod itself. It has already been painted(my apologies. Stress for time). I used a Tamiya F60 Ferrari as the base for my pod. The design was just what I wanted. After all, why go through the effort of scratch building when available models will do half the job for you. For me, what whatever works, use it. That's how the Millennium Falcon was built. The color used is a Automotive base coat reddish color. My choice of color is going to be this color, white and black.
Discussion Starter · #9 ·
11. I made my own seat-belts by using yellow tape from Tamiya, but we all know its made for Tamiya by scotch brand tape. Very please with it too. I used the one with the smaller width.
Discussion Starter · #10 ·
12. These parts will be add around the pilot compartment. These are parts taken from old bike kits. I know. Somtimes I just buys kits that has potential of being doner kits.
13. This is gong to be the jet propulsion that will be added to the back of the pod. I got it from another jet fighter doner. See. These doner kits are paying off.
How it looks installed. Not looking all that great but inside of this is not so trivial to the end results.
Curmudgeon
I'm sincerely fascinated. After more than four decades of building model kits, somewhere along the way I appear to have lost the ability to look at a kit and see something other than what it's supposed to be. So even with a box full of miscellaneous parts in front of me, I'd have difficulty putting them together in a way that makes some kind of sense. That being said, I'm looking forward to watching your continued progress on this project, and, of course, the finished product.
Discussion Starter · #14 ·
Thank you kindly. Much appreciate your overview.
Discussion Starter · #15 ·
Discussion Starter · #16 ·
14. Now due to the underside of the jet exhaust not completly clearing the bottom of the pod, it sticks out some millimeters from the base of the pod itself. So I had to find a way to accomodate the bottom plate that will cover the bottom half of the pod. So I came up with this idea. I just took a piece of styrene and cut it according to the curvy design of the bottom half of the pod, and then measured the width and length of the jet exhaust and cut out the area around where the exhaust will be. The result is what you see below:
My free hand cutting was not perfect but all this will be hidden in the final results.
Discussion Starter · #17 ·
15. Here are the parts that I've laid out, trying to decide what to use for the Electro Attachments on the pod. These will be connected by a long cable to the the engines itself. I wanted something cool, simple, yet high-tech looking. So I had to puzzle the parts to together and this is what I came up with.
The parts I chose to reprent the Electro Attachments.
Here are the parts disassembled and assembled just to give you an idea of the pieces involved.
Now the assembled piece. There will be one on each side of the pod.
Discussion Starter · #19 ·
17. Did some painting of the bottom engine half of the pod. I think it's starting to look like a machine rather than lots of plastic. Well, that's just me, trying to be positive. :)
18. Took the fan from a left over truck build. Since I build trucks, I have a few of these lying around. Painted it black and dried brush it with silver. I am pleased the way it came out.
Discussion Starter · #20 ·
19. I think I like the results of the bottom. Although, it will be visible, but one would have to bend their head just a little to look underneath. The details would be suffcient. Or maybe I should just add a mirror just under the pod. We'll see.
1 - 20 of 30 Posts
