I'd like to see a complete totorial on this build. It's not because it's so difficult but because I've thought about a similar build in 1=1.
I'm curious about the builders imagination paralelling mine. It seems he's already used a 6 cylinder engine.
Thx Gonzo
90% of what you see so far is the sweet pea frame and motor. the rest will have to be built. sweet pea is part of the jessie james diecast.
i would be happy to post a how to on this for you if you would like.
biggest probblem right now is all of the seating area out of sweet pea needs to be cut out for the 59 interrior to fit. or build around the sweet pea interrior. and use it. this idea came from a painting i found and can be seen on the thread whats on your bench.
i wanna add something to this build and use the rear off the 59 as a trailer with a hitch to go with the rat rod. i have a couple options on enclosing the fuel tank in on the rear or just using mini motors leaf springs over the axles.
or using the 59 rear tail section of the 59 to make it a shorty 59 with the tail light and tail gate. right now im going threw my stuff to find another jl 59.
i'll see what i can for a how to on this for ya. stay tuned:wave:
