Well yeah, as I understand it, at 1/64 with a max scale speed of about 250m/hr is real world about 4m/hr, a small breeze. If one where to apply a point system(my interpretation of someone else's research) to the factors affecting speed, avoiding extremes and luck, Total weight does not significantly affect velocity among the experienced builders, Weight placement is worth 3 points, favoring the back side of car center for drag racing(single lane tracks), and forward of center for fat tracks(road racing). Wheel friction gets one point(don't let them rub on the body and use graphite). And then there is the aerodynamic drag which is also suppose to be worth one point. Of course one should take a look at the things that affect drag.
For the testing of effects on your car you need a fan and an accurate scale. A scale that measures in milligrams (I have one on the way from Amazon for $25) must be protected for the breeze. To measure drag, tie a string to the rear of the car pointed nose down on a slight slope(for tension in the string) run the string over a pulley down to a weight on the scale. The less change in weight with fan means less drag. To measure down force, place car on platform that rests on but protects scale from direct breeze getting the tare in breeze first.
So, I have to yet to set up to evaluate the benefits but will post (maybe in a few months) when I have some data.
