Go Fast, Turn Left
I need a few ball studs that are 1/2" tall.
I have a couple of them on one of my cars, so I know that somebody makes them.
I need some more.
thanks in advance,
I need some more.
thanks in advance,
Hey Scott,
Josh at CEFX has a some different sized ones. He picked up a bunch caused they couldn't sell them. The threads were cut short. You can still put them through graphite and get a nut on them. I got a few. Not sure it they are that long though. I'll have them Sunday a BC if you want to look at them.
Couple of examples for you.
On the older H-drive cars we would use the taller ball studs to raise the outside of the side shock to take progression out of the shock and therefor allowing the car to rotate longer because it didnt want to stand back up so quickly.
The more angle you use the more progression a shock will have. that is why the newer cars have systems to allow for angle change built in.
You can also use different height ball studs to raise and lower roll centers.
Hope that helps
Rob @ Windtunnel Racing Products
