...begat the floating pick up
So I started playing with the wheelie pick ups and found that you could do other things with the idea. The wheelie pick up comes three different ways here.
1. Full on wheelie, as shown earlier. The shoe hooks are curled around allowing the assembly to open all the way up. Restriction is accomplished using wheelie bar adjustment or some form of tail skid.
2. The restricted wheelie pick up, where the assembly travel is limited by NOT over bending the shoe hook AND actually opening the hook angle so that the hook's end tang stops travel in the hanger slot. (no pix available) Restriction can also be fine tuned/adjusted using bars.
3. The floating pick up. Where the guide pin remains with the chassis. Wheelies denied by bars or leaving spring tension stock and adjusting the spring perch just before the shoe hook. This allows all kinds of fun with front tube chassis and altered wheel bases. Weeeeeeeeee!
If you look close you can see that the hanger window frames are retained, bent around AND USED to clamp/re-inforce the cross brace. (blown out braces were always a problem... not no mo!)
Ideally the brace is made as wide as the shoe step is long. The guide pin relief hole is made big because the travel arc of the pick up assembly dictates extra clearance. The screw head relief in the brace allows full upward travel.
The wheelie bars allow half travel of the assembly for good pick up float and electrical contact, but keep the guide pin in the slot.
Floaters used here to allow styling feedom. Restriction on this model is achieved using spring perch adjustment only. If you look close under this rod you can see the down bend just ahead of the shoe hook.
Here's one with the wacky bends like your linked set. This particular car is restricted using wheelie bars. The whacky bends are required to get the contact patches parallel to the rails because of the gumbo'ed rears. Keep in mind that when you mess with the modified pick ups you'll screw a few up before you get the angle of the dangle fingered out. (This one was reworked later to my later style floating pick up)
If there was any added advantage to all this....it made me a really good STOCK shoe tuner!
