4 wheeler boggin down
Im working on a atv for a friend of mine and i cant figure out whats going on. the fuel filter was completly clogged so i replaced that, the gas in the tank and in the bowl had gone horribly bad so i drained and refueled it with brand new gas, the spark plug was extremly dirty thanks to bad gas so i replaced that with a brand new one, the float was stuck and everything in the bowl was dirty so i cleaned it all out, but it still has trouble running. i can get it started after 5 or so kicks of the kick starter and it will idle for a while and die. and if i give open the throttle at all it dies. the only way i can get it started to ride it is if i hold the throttle all the way open and kick start it which takes about 10 tried but then it jumps and i nearly fall off. any suggestions. need help fast.
