1 - 3 of 3 Posts
My engines loses power when under load and climbing a slight incline. Otherwise it cranks easy and runs good. It does have a knock, however it doesn't smoke. Is this a rebuild I have to consider or are there problems that might be corrected short of that?
The engine seems to rev really high when I slow down or go to neutral ( hydro trans). This happens with deck engaged or not. My throttle cable has very little travel between idle and fully open. Is there a solution to this governor or new cable?
Thanks, Jakebob
1 - 3 of 3 Posts
