Does anyone make any? Im wanting to convert my brushless t3 over to a monster truck just for kicks.....I was looking but couldnt find any..
thanks
brian
when you take off the wheels of ur T3 there should be a pin that goes into the wheel when u put on thge nut. the T-Maxx has hex nuts that do the same purpose but the wheels have a hex shape in the center instead of and X. all u have to do is het a set of hex nuts and the tires and wheels you want ot put on ur T3.
I was wondering if that would work....I found a set of hex adapters and tmaxx wheels...if thats the case ill pick them up...
im not sure but i know some ppl put them on pede and they said that it steers fine. i don't know but it might work. if ur not sure then just get the masher 2000 tires. i had them on my duratrax evader st and it made a big difference uin the clearance.
thanks
brian
I know a kid that took the T3-diffs, arms, etc... Cut himself a new shorter alum chassis, made some adapters to fit up to AE-B4 rear rims & now he's has himself a 4wd monster mini... He races it in mini class offroad & dose well with it.
:jest:
