+1 :thumbsup:Get the integy auto truer. I don't know what the latest version is called, but its about 200 bucks plus arbors. You won't be sorry.
That's a good solution if you can afford to throw them out when they get worn unevenly and need truing.I have switched over to buying TM Tires. They come pre-cut for maximum race performance. No tire truer needed. I'm so glad I never have to cut tires again.
do they come with camber cut into the fronts?I have switched over to buying TM Tires. They come pre-cut for maximum race performance. No tire truer needed. I'm so glad I never have to cut tires again.
so you dont freshen up your tires after you run a couple races with them? what do you do? throw them away? or are they only good for a couple races then throw them away?I have switched over to buying TM Tires. They come pre-cut for maximum race performance. No tire truer needed. I'm so glad I never have to cut tires again.
+1 :thumbsup: I added a Hudy carbide cutter and everyone want to borrow this all the time.i have a 3 racing truer and it works good(2nd pic) but it has been discontinued and it works good and it was replaced with the (1st pic) but if i didnt have it i would probably get the integy or hudy truer.
i just also found out a cool thing about the new 3 racing truer has. it has a built in power supply(2--7.4 batteries under the bottom of the truer) or you can hook it to a 12 supply.
same here... havent cut a tire yet this season... :thumbsup:I have switched over to buying TM Tires. They come pre-cut for maximum race performance. No tire truer needed. I'm so glad I never have to cut tires again.
