1 - 11 of 11 Posts
i have an epic 27 turn brushed motor by express motorsports and all of a sudden it started making a squeeling noise... so i rebuilt it or well i turned the com and cut brushes cleaned out the can and all and it still does this anyone know why and what i can do to fix it?:freak:
easiest way i have found is after the motor is fully together use a syringe to put one drop on the bushings on each end of the can where the armature goes through them. a couple turns of the armature should help pull the oil where is needs to be. its best to use a very thin oil to reduce drag.
if the motor is not used for racing you can use bearings to replace the bushings. and the bearings will last a whole lot longer than bushings will. but if you are using the motor for a "stock" class race then it would make the motor illegal for racing.
1 - 11 of 11 Posts
