I'm using these two models to build a diorama of a cemetery and I'd like to know what scale this would be considered. I found some HO scale wrought iron fence with an arched gateway and wondered if this would look right around the perimeter of the diorama.
Thanks in advance,
Larry
Larry,
Most of the references I have suggest that the Monster Customizing Kits are 1/8 scale. Your HO scale fence might be a little small. However, it shouldn't be too hard to make a 1/8 scale picket fence from sheet styrene or balsa wood, unless it's the wrought-iron look you want. A doll house supply store might have something useful.
Have a great weekend!
mostly 1/8 , but there's a few pieces that are bigger ( couple of bones i think ) .
ya might check out the different sizes of florist' wire to make an old iron fence from . it's fairly soft and easy to work with .
stone and concrete parts can be made with polymer clay like sculpy or 2 part epoxy .
have fun .
hb
Discussion Starter · #4 ·
Thanks for the advice, guys.
I definitely wanted a wrought-iron look, plus, trust me when I say I have *no* sculpting talent whatsoever.
The dollhouse idea is a good idea though. I'll have to check that out next time I'm in the hobby store.
Larry
You can use toothpicks as the spindles and two wooden coffee stirrers as the top and bottom... You can make 8 inch long sections and then paint them black and dry brush rust and silver. Just a thought
Travis
