Hello,
I've got a weedeater featherlite and the part in the picture is not spinning. I'm hoping to replace it, wondering of someone can tell me what this part would be called? It came off the bottom of the shaft and connects to the spool.
Writing implement Asphalt Automotive tire Gas Cable
You will need the model number as Milton said, to look up the correct drive tube assembly with bearing housing assembly. No idea where the model info. is, I've only seen a few of those and not in many years at that.
The bearing blew apart on yours. Usually bent-shaft units don't have a replaceable bearing housing assy., and you have to buy the tube with it.
Here's one example, see drawing B, ref. #21
P.S. there's like 20 or so featherlite trimmers on ereplacementparts, so you need the model number to get the right part.
