1 - 13 of 13 Posts
Ok guys here is a question I have been wanting to ask for some time now. What is the best moderate priced weed wacker? Stihl, Echo, etc.
Also, what makes a commercial weed wacker better than one found at Home Depot...coould never understand why one lasted so long and the Home Depot weed wacker had a limited life span.
· Premium Member
Stihl and Echo are both good units. Commercial units are made much better. They have fully supported crankshafts, fully machined mating surfaces, drilled and tapped bolt holes, heavy duty shafts, etc. Home units have bearings on only one side of the crankshaft, no machined surfaces and are put together with self tapping screws.
I agree with Hankster, IMHO, it's whats going on inside those things at about 6-8 thousand rpm that makes the difference. I am still amazed that the ones with a bearing on one side of the crankshaft hold together for more than 5 minutes. Have a good one. Geo
Echo, Shindiawa, Maruyama, Stihl, Kawasaki, Tanaka. All very good and well built products, will last the average homeowner a lifetime with reasonable care. :)
Something else to consider is the dealer. I am a STIHL guy, but as others have said, there are plenty of other good brands out there. The problem is parts and service, if you ever have need of them.
A local dealer should provide good service and answer questions for you, and is an independent business, not part of a big box chain. The dealer is trying to make a living and provide a service. Echo, Husky, Toro, and many other brands play it both ways by selling through chains and trying to keep local dealers around to provide service. I used to be a dealer and this was a real stab in the back and sore spot for me.
STIHL, RedMax, and Shindiawa are about the only ones left that only use independent service dealers. Use the factory website to search with your zip code and see who is local and check them out. If they act uppity or like a jerk keep looking.
As far as the actual units go, STIHL has more experience in design and testing than anybody, and it shows when you compare similar units based on price or engine size. There are no longer in reed valve or cantilevered crank models in the line up, all are piston ported with bearings in each end of the rod and both sides of the crank, two rings, and if you will change the air filter every year, use 89 octane fuel and mix the brand of oil recommended at exactly 50:1 in the case of all STIHL models, use a fuel stabilizer additive to get it through the off season without the carb gumming up, it will last. I have seen a FS 100 STIHL trimmer used and abused commercially rack up 1200 hours of run time over a three year period with minimal repairs.
HTH
1 - 13 of 13 Posts
