Hi I am new to this forum but found it very resourceful when searching through it. I have a Weadeater BV 2000 blower with a Type 3 25cc 2 cycle engine. I cannot get it to start. I went through the basics that I could think of: it has good spark, no apparant exhaust blockages, cylinder and piston look great through the exhaust port, the cylinder appears to be getting gas/oil mix. I bought a compression tester finally since I am always fiddling with engines and it only tested at 50 psi. I ran the test dry 3 times with 5 pulls of the rope. I am thinking a worn piston ring/ stuck ring. I have not pulled the cylinder off yet but what do you guys think?
Discussion Starter #2
I just pulled the cylinder off and there is a couple of grooves on the exhaust side of the cylinder wall and the piston. They did seem deep. I cleaned the carbon off the top of the piston and put it all back together. I then oiled up the cylinder and did another compression test and got about 88 psi.
Do you think it is worth trying to hone down the cylinder and put new rings on? It looks like a new jug and piston kit would be about $40. I only paid $50 for it used.
Discussion Starter #6
OK ... sounds like the blower will go on the shelf for a project down the road! Now to rebuild my chainsaw.
