I know that there are alot of stuff out there for making water, but what would you all recommend for using to make a beach scene?
Also, how do you do the borders; meaning the water will touch three sides of the dio, so how do you keep the stuff from running off the dio?
Oxidation Genius
You could try 2-part epoxy resin glue with the right paint colours added; good points are that it dries looking 'wet' and is see-through, and doesn't need to be painted on its surface as the colour is already inside the 'water'.
Bad points are that as it dries it flattens to leave a smooth surface, so you have to keep roughing up the surface right up to the last minute; and that for a large diorama you'd need several packs of the glue.
Here in the UK the discount shops sell cheap 2-part glues at four tubes for £1, so it can be obtained fairly cheaply, and for a diorama water effect it doesn't matter how good it would have been as glue!
