Venom have released their all-new Medion Dual Output Charging station with integrated media player. Venom engineers listened to their Factory Team Pilots and they wanted music. So, they developed a rugged aluminium housed charger with a built-in media player featuring high definition 70mm drivers allowing you to pipe in your favorite tunes from your music player via a standard 1/8th inch stereo input. This charger features 400 watts of power via dual 200-watt circuits allowing for simultaneous charging of two batteries up to 10 amps each. The Medion also features a new IR-Mode™ internal resistance test which will test each cell individually and provides single cell and total pack resistance values so you can see the real-time condition of your LiPo and LiFe battery packs. All this technology is accessible through an easy-to-read red, backlit LCD display.
Features:
- Dual 200-watt charge circuits
- Twin 70 mm Audio Drivers for crystal-clear sound
- 1/8 in Line-in compatible with any MP3 or Smartphone
- Charges LiPo, LiIo, LiFe, NiCD, NiMH, and PB (lead acid) batteries
- Integrated cell balancing software for LiPO, LiFe, and LilO packs
- IR-Mode™ measures the internal resistance of Lithium battery packs
- 5V/1A USB output to power smart phone charger or included LED Light
- Programmable battery profiles for up to 5 different battery types
- Programmable thermal temp alarm with auto shut down
- Capacity cut-off and timer safeguards
- Temperature controlled cooling fans
- Includes USB powered LED light
- Includes temp probe and balancing block
- Includes Traxxas®, EC5, EC3, Deans and Tamiya adaptor plugs
Specifications
Input Voltage: 11.0 – 18.0V
Circuit Power: 200W max charge x 2, 25W max discharge x 2
Charge Current: 0.1 – 10.0A x 2
Discharge Current: 0.1 – 5.0A x 2
Current Drain for LiPo Balance: 200mAh/cell
NiCD/NiMH Cell Count: 1-18 Series
Lithium Cell Count: 1-6 Series
Pb Voltage: 2-20V
Alarm Voltage: Lower than 10V or greater than 18V
Weight: 3 lbs 10 oz (1650 g)
Dimensions: 11.8 x 5.9 x 3.35 in (300 x 150 x 85 mm)
Balance Block: 2S-6S
Click here to view the embedded video.Input Voltage: 11.0 – 18.0V
Pb Voltage: 2-20V
Source: Venom [venom-group.com]
More...
