21 - 34 of 34 Posts
Discussion Starter #22
Finished drilling and carving for the nacelle strut wiring...
I drilled these holes from the inside for wires to pass thru up into the nacelle struts:
USS Enterprise E - Nemesis-WIP- Holes for Nacelle Strut Wires
by Steve J, on Flickr
The holes match up to channels I carved out of the lower nacelle strut half:
USS Enterprise E - Nemesis-WIP- Holes Outside
Using a triangle, a mechanical pencil, a scriber, and my battery powered hobby dremel with a fine grinder
bit I dug out channels in the trailing edge of the two lower nacelle strut halves:
USS Enterprise E - Nemesis-WIP- Making Wiring Channels
I initially had planned to put the channels further to the right in this photo where the tab fits into the hull,
you can see how far I got before realizing the plastic was too thin because of the recessed vents (?)
present on the other side of the part.
The plastic was thicker along the training edge and I didn't have to deal with carving and possibly weakening the tab:
USS Enterprise E - Nemesis-WIP- Wiring Slots
Back to the nacelles...
Various stages of priming and light blocking the interior nacelle halves and the lower half of each nacelle strut:
USS Enterprise E - Nemesis-WIP- Various Stages
Krylon Satin Black is sprayed inside each nacelle half.
Hopefully it doesn't get under the masking tape:
USS Enterprise E - Nemesis-WIP- Nacelle Light Blocking
So that brings us up to date on this build. Looking forward to getting my flasher/strobe board from Tenacontrols. Hopefully I'll get it later this week or early next.
In the meantime I can work on the rest of the lights.
Stay safe and try to restrict any "treks" outside.
Discussion Starter #23
Sorry for the long delay between posts but I've been spending a lot of time working on the nacelle lighting. I finally got them sorted out though and glued together. Unfortunately, my camera and work laptop aren't communicating. My company has clamped down on any use of the USB port (the one I plug the camera into) for anything other than company approved uses so all of the in-progress photos on my old Canon DSLR are not able to download, possibly until I get a new camera with wi-fi access and/or I get my own laptop.
So I'm relegated to uploading photos taken on my iPad to Flickr! I took this photo this morning though so you guys can see how the lighting effect looks...
USS Enterprise E - Nemesis-WIP-Nacelle Lit
Three amber/red LEDs light the bussards which were painted on the inside with Tamiya transparent red acrylic. I used cotton to act as a diffuser around the LEDs. The top of the nacelles are lit by hi-density blue LED strip beneath a strip of translucent milk jug plastic which acts as a diffuser giving the nacelles a nice even glow. I still have to attach the clear kit part on the top of the nacelles but I may want to attach the photo-etch brass grills first.
The camera washes out the colors to some extent; to the naked eye the colors are more intensely blue and orangish red.
There will be two flashers on the aft end of each nacelle (top and bottom) which will be lit by fiber optic strands fed by a single cool white LED mounted inside. You can see a separate set of wires in the photo, the pair nearest the trailing edge of the pylon. They will flash once I solder the wires to the Tenacontrols flasher board which I will mount in the saucer.
More to come as I start drilling out some, not all, of the windows on the rest of the ship.
Discussion Starter #27
Did some work on the quantum torpedo port...
A slot was drilled and filed out previously for the quantum torpedo launch port which is just above the Captain’s yacht in the underside of the saucer. The port will glow blue thanks to a transparent blue styrene part leftover from the 1/350 TOS Enterprise light kit. The part was glued in behind the opening with epoxy. It will be lit with a 2mm LED:
USS Enterprise E - Nemesis-WIP - Quantum Torpedo Port
I glued the K size power jack into the secondary hull with epoxy. Later I’ll pack some AVES Apoxy Sculpt in around it for added strength:
USS Enterprise E - Nemesis-WIP - Power Jack Installed
The inboard and outboard pylon halves were glued together with Testors tube glue for both pylons:
USS Enterprise E - Nemesis-WIP - Pylon Inboard Half Attached
After spraying with adhesion promoter followed by Krylon Grey primer I will attach the upper nacelle grill halves using metal foil adhesive which is basically a tacky white glue. This water based glue will not craze clear plastic parts. I had already painted the raised center strip with Krylon white primer over Krylon flat black for light blocking down the middle of the clear covers:
USS Enterprise E - Nemesis-WIP - Nacelle Grill PE
Took about two hours to finish gluing and cleaning up the brass nacelle grills with isopropyl alcohol on a cotton swab. The metal foil adhesive makes a sticky mess and there’s no way to avoid getting it on the painted side of the grills while you work to separate and space the grills while burnishing them down:
USS Enterprise E - Nemesis-WIP - Nacelle Grill PE Installed
More to come. Think I’ll work on the impulse engines next.
Trekkriffic,
It's been quite some time but I wandered back to this site. I saw your build and am impressed. I know you did LED lighting for the nacelles, but take a look at this LED neon strip. You can cut it and solder it and I think there is enough in one item for both nacelles and then some. The beauty is, it is already diffused.
Flexible Silicone Neon-Like LED Strip - 1 Meter
I see DigiKey has them in stock.
Good luck and keep us posted with your build!
May the FORCE be with you and have a magical day!
MagicBill
Discussion Starter #33
Trekkriffic,
MagicBill
Thanks Bill. The high-density LED strip I used actually does have a layer of silicone rubber laid atop the LEDs for diffusion. I'm not sure if the neon strip you mention can be cut to the same 6 inch length as the strip, although, I agree, it is an elegant solution for eliminating LED hot spots.
Steve
Discussion Starter #34
Update...
I had been debating whether or not to open up the window ports or just rely on gloss white paint to give the illusion of lit windows. Then I thought about how cool those low light shots of the E looked with all those rows of lit up window ports so I finally decided to just go ahead and bite the bullet...
Using a pinvise and a fine pointed round file I commenced drilling out the saucer windows. Some of them will not be drilled out so I can paint them black later on. This took me about 6 hours and I am probably about only half finished with the upper saucer:
USS Enterprise E - Nemesis-WIP- Drilling Out the Saucer Window Ports
The windows show up well when backlit. Still have a few hundred more to drill out:
USS Enterprise E - Nemesis-WIP- Saucer Windows
After drilling for What seemed like hours on end I took a break to work on the impulse engines and shuttle control room part...
This is one of the two impulse engine vents. I sanded off the raised detail on the clear kit part and glued the PE grills in place with metal foil adhesive per the PE instructions. Then I used the aftermarket decal, putting it on the inside face of the clear part. It will be lit by a red LED:
USS Enterprise E - Nemesis-WIP- impulse Engine Vent
I removed a section of the saucer shuttle bay control room face and glued in a rectangular piece of clear styrene. The PE window frame will be glued on over the clear styrene with metal foil adhesive. Then I will use styrene strip to frame around the PE frame as the windows appear to be recessed from what I see in images of the external bay. The windows will be lit by ambient light inside the saucer:
USS Enterprise E - Nemesis-WIP- Saucer Shuttle Bay Control Room
OK... well... back to drilling windows. Hope to be done with them by July.
Steve
21 - 34 of 34 Posts
