1 - 20 of 22 Posts
LED Burner Outer
One temporary trick with loose tires is putting a wrap of masking tape around the rim, and then putting the tire on. Is that car the R/C looking thing with the fat knobby tires on it? I might have a couple sets if that's what they are.
Stagger, stagger, crawl.
A piece of shrink tubing will also work but it's a bitch to remove. Either option also raises the car away from the track.
be careful with soaking rubber, some chems will cause rubber to expand a lot!
I did a t-jet tire once that got as big as a donut! it did shrink down after that but was very lose on the hub.
I would try rubber renue or 1 of the RC car chems that softens the rubber.
apply on the inside and out, it may not shrink it, but would give more grip.
Not sure if a blow dryer would dry out to much, but it should shrink it some, but then again, the rubber renew may help stop it from drying out???
Part Time Painter/Racer
Just wandering here, could you cut it with a razor blade, trim off a hair, and use some CA glue to bond it back??? Some of that glue is suppose to bond rubber. I'd cut it, lay it flat on a piece of wax paper, add some glue, then push the ends together...might work, might not...RM
1 - 20 of 22 Posts
