1 - 3 of 3 Posts
I want to run one power pack per lane on a Tyco HO race set. I have a standard Tyco 20.8 VDC - 4.9 VA unit. I could get another one that matches. Or, I also have a Command Control power unit with 21.7 VAC - 6.6 VA--I may be able to match this one as well. The plugs don't match the track I have, but could I adapt it?
I do not understand the consequences of the VAC vs. the VDC.
Also, will a higher VA produce more speed in the cars?
Thanks for any advice.
You could adapt different connectors by splicing them into the output wires. Pay attention to + and -.
Volt Amps on DC wall warts is a rating without load. Depending on what you want to run on your track, you may want to double up wall warts in parallel for better amp output. Those with a better understanding of electrical science can explain the formula for getting volt amps.
Higher voltage will give you more speed. Higher amperage will get you to a speed faster and allow multiple cars to draw amps without surge.
1 - 3 of 3 Posts
