1 - 2 of 2 Posts
Compression established---bounce back test
Spark--tester reads nice audible, blue spark
Fuel-carb cleaner squirted in combustion chamber
engine should start, at least for a few seconds
True or False ?
comments appreciated....
ariens snowblower-Tecumseh engine more info if needed
thanks
Generally, yes it should fire off. You need to make sure the ignition timing is correct. A sheared or partially sheared flywheel key could be a factor.
1 - 2 of 2 Posts
