Hi, When I turn the key I get gas blowing out of the top of the carb (with air filter removed) and then it acts like the motor is locked up (starter just stalls). If I manually turn the flywheel back it will crank until the stop point(locked up point). Could this be a flywheel key partially sheared? This is a 31X7070777E2.
Oh, the belts underneath are off and the mowing deck is off. Thanks for any help.
