The thing that gets me about those points though, is that they all fall under the "well duh!!!" catagory.
They want it to look like buying a brushless is worse than buying brushed, but all those points are just common sense.
"Only Need One Motor: False, you will still need several motors for each application you decide to use them in.
~ Again....DUH! No, I'm thinking my motor will magically move itself from my truck to my buggy.
"Motors are Indestructible: False, Brushless motors can still be susceptible to shorts due to faulty winding, debris entering the motor and heat."
~Hmm, well I really thought if one had accidentally been made poorly, it would work better! (extreme sarcasm). Not to mention, how is this worse than brushed motors that would have this still happen more often.
"Torque and RPM are the same as brushed: False, you will need to give up one for the other. That is another reason why you need more then one brushless motor."
~ Uh, I know I've said this before but....DUH!!! I think everyone knows, simple physics only allows for one or the other. Sigh....how stupid do they think we are?
"No Maintenance: False, cleaning, bearing replacement and magnet zapping will still be needed for top performance. Also, any damage to the motor can may cause the motor to fail."
~Well of course if you abuse ANYTHING, it will eventually go bad. I was thinking I could throw a few screws in there, throw the motor against the wall, and think it would still work......sigh...
"Brushless will take the battery war out of play: False, Batteries will play a bigger part since brushless systems depend on high voltage, amps and super low internal resistance to operate as a race motor. Bottom line... you will still need to have quality batteries."
~This one may be true, but I honestly have never heard anyone say that it would take batteries out of play.
"Some say the Speed Control can be programmed to a spec level and everyone will be the same: False, again at this point batteries will make a huge difference."
~No this is true, you can program the esc to a spec level. Batteries are a completely different issue.
I don't even own a brushless system, and honestly, don't care either way. I actually enjoy working on my motors and rebuilding them, so as long as they are more powerful, I will use them, but what Trinity is trying to imply is just stupid of them!
