Numbers of TRAXXAS R/C model parts for monster truck has just arrived rcMart.com! Please check the list below for your desired Traxxas parts:
Model No. Product Name 1951 Half Shafts, Long Truck 2419 Pinion Gear 19T 48P w/Set Screw 2423 Pinion Gear 23T 48P w/Set Screw 2555 Suspension Arms (Rear) 2556 Headerscrews 3x23mm 3080 Traxxas Connector (female) (2) 3632 Caster Blocks (30-degree) 3637 Axles (Front) 3736 Steering blocks, left & right (2) 3752 Stub Axle Carriers 4725 Pinion Gear (48P 25T) 5329 Bulkhead, rear (L&R halves)/ diff retainer, rear/ 4x14mm BCS (4) 5458 Yokes, Differential and Transmission 5460 Shocks, GTR aluminum (assembled) (2) (without springs) 5469 Rod Ends (GTR shocks) (6) 5531 Suspension arms, front (left & right) 5533 Suspension arms, rear (left & right) 5535 Bumper, front 5561 Shocks, GTR composite (assembled) (2) (without springs) 5656 Half Shaft Set (Long) 2742x Rod Ends, short (6)/ hollow balls (6) 4628X Differential output yokes, hardened steel (w/ u-joints) (2) 4935X Bumpers, 6061-T6, brushed aluminum (f&r) 5312R Body, Revo 3.3, ProGraphix (extended chassis) (replacement for painted body. Graphics are printed, requires paint & final color application)/decal sheet 5312X Body, Revo 3.3 (extended chassis), ProGraphix (replacement for painted body. Graphics are painted- requires paint and final color application)/window, grill, lights decal sheet 5338A Toe links, Revo (Tubes 7075-T6 aluminum, black)(128mm, fits front or rear) (2)/ rod ends, rear (4)/ rod ends, front (4)/ wrench (1) 5338R Toe links, Revo (Tubes red-anodized, 7075-T6 aluminum, stronger than titanium) (128mm, fits front or rear) (2)/ rod ends, rear (4)/ rod ends, front (4)/ aluminum wrench (1) 5458x Yokes, Differential and Transmission 5918X Aluminum Push Rod For Slayer Where to buy:
http://www.rcmart.com/catalog/hopup-parts-traxxas-c-595_739.html
