1 - 1 of 1 Posts
The NEW E-Maxx Brushless Edition
With Castle Mamba Monster Power System, TQ 2.4GHz Radio,
and Traxxas Power Cell 8.4v NiMH Batteries
The new Traxxas E-MAXX brushless edition is coming soon to rcMart. Wanna be the first to order this new chassis? Don't miss our latest news at rcMart or RSS.
The Traxxas E-Maxx Brushless Edition is packed with Maxx Monster Muscle for boulder slinging torque and scorching top speeds of 65+ mph. Power comes from the Castle Creations Mamba Monster, factory installed and programmed for maximum output from the 2200kV motor. The included twin 7-cell NiMh
battery packs power the E-Maxx to a scorching 35+mph. Strap in 6S Lipo and install the included optional speed gear, and the next stop is 60+mph. If speed is your ultimate goal, 65+ is possible with a set of lower profile Talon tires (sold seperately). The E-Maxx requires no modifications to handle the extra power; all of the drivetrain and transmission components were designed from the start for exactly this type of high-amp, high-rpm horsepower. Super-Duty Revo® driveshafts, Torque-Control slipper clutch, an oversized steel idler gear and rubber-sealed bearings are just a few of the features that make E-Maxx ready for all the horsepower you can handle. The Mamba Monster™ controller features a cooling fan and heavy-duty construction with oversized 6.5mm connectors, Traxxas High-Current Connectors, and the motor uses a 5mm rotor shaft for added durability. Traxxas’ innovative and secure speed control mount keeps the Mamba Monster controller and on/off switch in place without relying on servo tape. The E-Maxx Brushless Edition also includes the Traxxas TQ™ 2.4GHz radio system that eliminates frequency conflicts while delivering the long range and reliability you expect from Traxxas.
What’s New
• Castle Creations Mamba Monster brushless system with 2200kV motor
• TQ 2.4Ghz DSS radio system
• Pre-installed four-position wheelie bar
• 6.3” Maxx® tires on black-chrome Split-Spoke wheels
• Black-chrome bumpers
• Progressive rate springs
• New body with bold graphics
• Dual waterproof 2075 digital ball-bearing steering servos
• Aluminum 17mm splined wheel hub and hex nut
• Aluminum Torque-Control slipper clutch friction pads
E-Maxx Brushless Edition Features
• Factory-installed Castle Creations Mamba Monster™ Brushless System
• Speeds of 65+ mph
• Two 7-cell 3000mAh batteries included
• Heavy-duty Brushless Ready transmission with steel idler gear and Revo®-Spec Torque-Control™ slipper clutch
• Revo®-Spec front, rear, and center driveshafts
• TQ 2.4GHz DSS radio system eliminates crystals and frequency conflicts
• Quick release battery hold-downs accept 6- and 7-cell NiMH packs and 2S LiPo packs
• Accessory battery hold-downs included for 3S LiPo packs
• Dual digital waterproof steering servos deliver 250 oz-in of torque & 0.16-sec transit time
• Eight fully-adjustable, coil-over Ultra Shocks™
• Sealed pivot ball suspension
• Sealed limited slip differentials
• Hex hardware throughout
• Ready-To-Race®
Castle Creations Mamba Monster Features
• Rated for 6S LiPo operation
• Low-voltage detection for LiPo use
• Heavy-duty switching BEC
• High-efficiency heat sink
• Integrated cooling fan
• 6.5mm gold-plated bullet connectors
• Castle Link compatible for tuning via computer using USB cable
• Proportional heavy-duty braking circuitry
• Proportional reverse with lockout mode
• 5mm rotor shaft
• Machined heatsink motor can
(Click the picture to enlarge)
1 - 1 of 1 Posts
