I purchased Tracker 2000 to help me design my next track layout. I'm starting to get the hang of the software - the split/join track feature is nice.
I'd like to get your input on the current design I am working on. I have uploaded the .tr3 file in case you would like to assist by modifying it.
The file will show my current inventory of track. I was a bit shocked to realize that even after purchasing an SI set and a BBB set (along with a few more pieces) I am still about $150.00 short in needed track based on this design
So the track has started to slowly change, as I try to use more of my inventory pieces. But, I don't want to build a poor track just because I'm trying to only use what I have.
The layout is 2 4x8's, and since they will be stored seperated, I am trying to keep straight pieces over the split, so when I carefully pull the tables together, I can make the track connections over the split. I am also trying to keep the track flat, since the tables will be stacked with spacers and raised to the ceiling of my garage. However, I'm tempted to work in the few 12" banked pieces I have, to save some $$ on more track.
Anyway, suggesstions on improving the design are appreciated. Even negative comments will be appreciated. I have virtually zero experience running slot cars, so I'm not sure what really works, and what doesn't.
Thank you.
Thank you.
