41 - 60 of 516 Posts
Is everyone running these with the kit setup. I'm thinking about getting one, I just don't want to get blind sided by anything. I'll eather run 17.5 truck or pro stock. How do these compair to the lithium as that is what I curantly have.
I've had the car about a month now and mines pretty dialed everywhere I've been, If you shoot me you email I'll send you the setup I run at home and what I ran at Ovalmasters.
Justin,
Can you post it on the thread. i would like to see it as well to compare against mine. My car was pretty dialed at a 2 day we had in Colorado a few weeks ago.
Justin,
First is what I ran at Ovalmasters, seconds is what I run at Home (rosewood) and is really close to stock,just minor tweaks.
https://docs.google.com/open?id=0B1iRklKQy5f5NjVjZTQ1N2MtMWJlZi00ZmMzLWI4MjgtMjJhNzAyMjhkMzVm
https://docs.google.com/open?id=0B1iRklKQy5f5YjdkOGRjYzQtM2M1Ni00ZTA1LTliMGMtNjY0NTA2YzVhODYw
Discussion Starter #46
It is so much faster in the corners.My driver in truck lapped the hole filled by 2 or more laps the first time out.
Thanks Scott for your help on the Top parts. There is some good support here behind these cars and the parts for them.
Also the car comes with long kingpins and the spring bucket to use big front springs. I used KSG Blacks (wolfe reds will work) and wolfe opaque sides 11# and wolfe yellow center 9#. Made the car really easy to drive. Think this will be a goto setup for bumpy tracks even though I liked how it felt on smooth also. I'll post a setup sheet later this week.
Couple of questions. Does this car use metric or the normal sae bearings? Also will an associated front end work if I don't have top parts with me and how big of a spur gear will the pod accomodate? Thanks in advance
The car uses normal bearings, the Associated front end won't work. Its tough to say exactly how big of a spur you can run without knowing what tire size and rollout your aiming for. I can tell you with a 80 tooth spur you can get a range of 3.6-4.5 rollout with a 2.10' tire.
Discussion Starter #52
I would think so ,the steering blocks are not diff. but to be sure I will pull a new set out of a box to check and let you know.
Should've been more specific,I'm going to be doing some cap tire racing with it and i like to run spurs in the 105/110 range
