1 - 1 of 1 Posts
The TLR Ten-SCT is a no-holds-barred Nitro powered SCT RTR that’s ready to take on the toughest of all competition when you are. With its on-board remote start (R.O.S.S.) system, you can kiss goodbye to pull-starting and having to carry a separate glow igniter around with you; simply prime the system and hit the start button on the Spektrum DX2L 2.4GHz Transmitter. The Ten-SCT shares the same race-winning geometry and oversized durability that has made the Ten-SCTE such a hit already with racers and SCT fans around the globe. This is a heavy-duty truck that can take all the punishment you can throw at it and still come back begging for more. The new waterproof servos and weather-resistant sealed radio box means that the fun doesn’t need to stop if the weather turns against you and the 1.8HP from the 3.4cc small-block motor and tuned pipe is sure to put a grin on your face as soon as you squeeze the trigger.
Features
- R.O.S.S. – Remote On-board Starting System
- Spektum DX2L Transmitter
- Waterproof, sealed radio box
- Waterproof steering and throttle servos
- Lightweight anodized aluminium chassis
- Oversized 12mm anodised, threaded shocks
- Heavy-duty, 4mm tie rods with captured ends
- Twin disc brakes for quick and reliable 4-wheel stopping
- Tank clunk for fuel pickup even when rolled over
- 2-shoe centrifugal clutch
- 12mm wheel hexes
- Eclipse Short Course truck tyres
- Beadlock-style SCT wheels with rings
- Functional mud flaps
- Losi 3.4cc performance engine with slide-valve carburetor
- High-performance tuned pipe designed to maximize the 3.4’s potential
- Two-stage air filter system to ensure a clean air intake
- Sway bars included for better control and handling
- 7.4V LiPo receiver battery pack and charger included
Specification
Scale: 1/10
Completion Level: Ready-to-Run
Length: 524mm (21.34 in)
Width: 295.8mm (11.65 in)
Weight: 3.06 kg (6.75lb)
Wheelbase: 334mm (13.15 in)
Chassis: Anodised Aluminium
Suspension: 4-wheel independent long-travel
Shock Type: Aluminium
Drivetrain: 4WD with 3 gear differentials
Differential: Sealed gear
Tyre Tread: Eclipse SCT
Engine Size: Losi 3.4cc
Radio: Spektrum DX2L
Servos Included: Yes
Body: Losi SCT
Ball Bearings: Complete
Recommended Environment: All-Terrain
Fuel Tank Capacity: 82cc
Click here to view the embedded video.
Source: Horizon Hobby UK [horizonhobby.co.uk]
More...
1 - 1 of 1 Posts
