Yet another question.. can you tell I'm just getting back into it?
Is there a reason why you would go with foam tires in some instances, and capped tires in others? Does it matter if its stock or modified? What do they run at the big races - regionals and nationals?
Also, at this local track I just found, they were using suntan lotion as tire prep! I'd never heard of such a thing. Is this common, or something only they do?
I'm really wondering if this one isolated track is an oddball group, or if some of the new stuff is common place.
The track is a banked Asphalt oval. If you are set up right you can run flat out with a stock motor. If your pushing, you have to let off just a touch.
They are running Greens in the back, blue's in front, and the afore mentioned suntan lotion. Everyone else I see on hear is talking about purples and pinks.
Thanks again for your help.
