1 - 2 of 2 Posts
Briggs 35 classic engine, The throttle springs are weak and sometime she will start sometime not, when she does run she is awkward to idle. what does each spring do so I can set the throttle or where can I get replacements. google searches for spares have proved useless.
Post the mode type and code numbers from your engine. Governor springs are model specific, once you have the correct part numbers, you should not have any problems finding them online or at a local small engine shop.
1 - 2 of 2 Posts
