Does anyone know if the saucer kit from the TV series "The Invaders" will ever be re-released
TIA
TIA
I just hope if and when Mono-Revell issues it again they decide to include the clear top like the 1st Aurora issue with it.
Steve
Yeah, problem with that is that the bottom part is integral with the the entire hull. And to do clear, not only would the entire part have to be done in clear, the entire sprue would have to be done in clear. Which means that almost the entire kit would be clear, and I doubt they would do that.That's a must. It could either be left clear so the inside can be seen or the windows could be masked off and the rest sprayed silver. And the large engine underneath should be clear too (even in clear orange plastic which I seem to recall was in the show).
I've been seeing these things around for reasonable prices - keep looking and you should find one......
Gene
I like models in clear, but I think in this case for the few who would add lighting it would not happen. The good thing is that that Engine panel can be cut out and plastic from a ceiling light diffusor can be made to fit- that even has the diamond texture in it.
My problem with the original kit is that ithe entire hull is out of proportion to the ship as seen in the series. There was an extensive thread in this forum a while back with a lot of great reference images.
