This thread is to show my testing on various packs available on the market to show how similar most packs are as far as Internal Resistance which is directly related to the C rate of the cells/pack.
In my testing I noticed that performance data is only one part of the story when it comes to testing packs. It seems that packs from different factories have there own way of evolving over the cycle life of the pack. I attribute this differences to the raw materials used and how the cells are built.
I hope this thread will be used as an educational thread to help consumers better understand that a pack from factory A is different than a pack from factory B.
My testing consists of testing the cells IR using the ESR meter to see what kind of performance and C rate the pack has to offer.
I then do cycle life testing which consists of doing back to back cycling on a GFX using a 12 amp charge and 35 amp discharge with a 10 minute break in between cycles. I graph the results of cycle 1 , 25 and 50. If a pack does o.k. after cycle 25 I will go up to 50. In some cases I have to stop after the 25th cycle as the pack drops to much mAh.
My cycle life testing method is most likely harsher than what can happen in real world use but since I treat every pack the same this test is showing the difference between various packs.
I've decided not to reveal the names of the companies who sell the packs I'm testing as my goal is not to attack my competitors but to educate the consumer.
Hope this thread will help everyone better understand more about LiPo packs.
