Hi to all. I just last night ran into a problem while using my Ariens Snowblower with an electric start Tecumseh H70 to attempt to clear some of the 17" of snow we just received the night before last and into yesterday morning. I had thought it would be ready to run, after changing points, condenser, plug, oil, and rebuilding the carb. After I got done last summer it started right up and ran well after I fine-tuned the carb screws. I started it this Fall and ran it fir a while with the same results. When I went to use it for the snow the other day, the same thing - started right up and ran well. I used it far about an hour blowing snow with no difficulties, and then suddenly I started hearing a ticking sound (valve?) near the top of the engine. the engine began to skip and would hardly stay running without me playing with the carb linkage with my finger, and would eventually stop. It would restart immediately every time it quit, but with the same result. It chugs, skips, won't accelerate at all, and emits some black smoke from the muffler-along with this regularly-occurring clicking/ticking sound up top. I think it's a problem with either or both valves, but not sure what happened. And it was running so well just before. I haven't touched it yet,, because I want to be sure where the problem is before i start a fishing expedition. It's not the carb, not the state of tune or spark, not the fuel nor compression, and not the crank and rod. Oil is full; no lower end noises or knocking.- Waht do you all think? thanks very much. Curt
