I currently have in my shop a Roper snowblower with a Tecumseh engine on it.the problem with it is the throttle lever on the handlebars will not change the speed of the engine.The linkage cable is moving the mechanism down at the carburetor , however , I do not believe things are configured correctly. the customer told me that he messed with it before bringing it to me.the speed will change when you take your finger and manually move the throttle plate.the whole Governor/ Throttle arrangement is not what I believe put toghether correctly. The motor is an HM100 159035C Serial # 8265C. I looked in the Tecumseh repair manual in the carburetor/governor section and the diagram for a Horizontal Mediun frame does not look like what is on this particular engine. It is not a Snow King engine, just an HM100.I need some info on how this throttle linkage/governor linkage goes together and why it will not respond to the throttle lever.
Thanks in advance for your help,
Mark
Mark
