I am working on a somewhat late model Toro Recycler with a 6.5hp Tecumseh. It appears it was under water as the aluminum has a lot of powdery coating to it, and all the other ferrious parts are fairly rusty.
I am able to get the engine running again by replacing the carb- the original one was so badly rusted inside the pin the float rides on was welded to the carb body- however, it only runs for about a minute or two and dies. When it dies, it is like somebody turned off the switch- no sputtering, coughing, wheezing- just dead. It wont restart, or even act like it wants to, even using carb cleaner sprayed into the throat, not until it cools off.
Now I have heard from a long time pro in the business that mower coils are either good or bad, no in between, no failure due to heating up, but it sure seems like when the motor gets warmed up the spark is quitting. I know my old 40 Ford had a bad coil that would start missing when it got good and hot. Could it be that water soaked into the coils windings, or maybe the surfaces where the coil mounts- or some other ground- are corroded and break the circuit when hot?
