I was mowing the lawn the other day and hit a stump. Mower immediately shut off and would not restart. When you pull the cord, the engine does not start. It seems like when I pull the cord the engine only turns over one revolution. I replaced the flywheel key since it was pretty much sheered off. I thought that would fix the problem, but appearantly not. Also after replacing the flywheel key, I was pulling the cord checking things out and it yanked back and almost took my hand off. Any suggestions?
Discussion Starter · #4 ·
How can tell if its the shaft, what do I look for? About how much is a new shaft? Is there anyway to straighten the old one? The mower is a couple of years old, would it be worth fixing?
79t/a is right if the blade is straight and when you spin and it wobbles it's cheaper to buy new. go buy the same type and keep the old one for parts to fix the new one when it needs it ...........if its bent. if the blade is bent not the shaft the blade could be catching on to something take it off and spend the money on a new one fixin the old one will screw the engine up
