1 - 1 of 1 Posts
Based on the 7-time National Champion RC10T4, the brushless RC10T4.1 from Associated is a fully assembled truck that features many of the components from the RC10T4 Team kit, while incorporating a totally new 2.4 GHz XP3-SS 3-Channel radio system and SHV1504 MG metal gear steering servo. Power is supplied by a Reedy 3300kV brushless motor while the XP SC450-BL electronic speed control with LiPo cutoff provides smooth throttle control. A sealed gear differential improves reliability and allows fine tuning for different track conditions. Also available in a brushed version, which is supplied with a 17-turn Reedy motor and XP SC200 electronic speed control.
RC10T4.1 Brushless RTR Features:
- Built on the 7-time National Champion RC10T4 platform
- XP3-SS 2.4 GHz 3-channel radio system w/ SHV1504MG metal gear servo
- XP SC450-BL Brushless electronic speed control with LiPo cutoff, forward and reverse with reverse lock out
- Reedy 3300kV brushless motor
- 2.6:1 ratio gearbox with sealed gear differential, dual-sided adjustable slipper clutch, and rubber sealed ball bearings
- Molded composite low-CG chassis with set-screw antenna tube lock
- Blue aluminum shock bodies with molded pre-load clips
- Battery strap with twist-lock thumb knobs
- Rugged steel turnbuckles for adjustable camber and front toe-in
- Angled bellcrank “co-planar” steering with built in servo saver
- Vertical ball ends for roll center adjustments, front & rear
- Pre-mounted tires on white dish wheels
- Factory finished Interceptor-T polycarbonate body
RC10T4.1 Brushed RTR Features:
- XP SC200 electronic speed control with LiPo cutoff, forward and reverse with reverse lock out
- Reedy 17-turn motor
Source: Associated [rc10.com]
</img>
</img>
More...
1 - 1 of 1 Posts
