1 - 1 of 1 Posts
While you are out picking up your connectors and diff balls, stop by your local machine tool store and pick up a left hand and a right hand 4-40 tap. They should cost you less then 10 bucks. Then use them to tap out your ball cups, suspension arms and anyplace else you use a 4-40 screw in plastic. Not only will the screws go in straighter and easier, but the threads will be stronger.
1 - 1 of 1 Posts
