1 - 1 of 1 Posts
*Click the image to buy
The Tamiya (#74089) Electric Screwdriver Set (PT01) has just arrived @ rcMart.com
【 Multi-Purpose Electric Screwdriver 】 Tamiya proudly releases this Electric Screwdriver Set which can be conveniently used for assembling R/C models and for other DIY purposes. This screwdriver features 21 adjustable torque settings, and the clutch function stops the motor to prevent the screwdriver from damage in the case it faces more torque than the set value. The equiped lock button allows you to use this electric screwdriver in the either the standard pistol shape or straight forms. Also comes with a forward/reverse switch button as well as high/low speed select lever. In addition, the included LED light allows you to clearly see the area you are working on improving your work efficiency. The built-in 7.2V lithium-ion battery can be fully charged in approximately 30 minutes with the included AC100V charger. The set also includes soft case and 5 screwdriver bits which can be easily attached and detached by simply sliding the sleeve.
Feature:
- For: Miscellaneous
- Color: Black
- Rechargeable
- Tightening torque can be set to stage 21, when it took over the setting torque motor stop working while the clutch mechanism
- Features a lock button can be used as tack drivers
- Forward and reverse function
- High speed and low speed switching lever
- The pistol can be straight, according to the work to fit
- High-brightness LED light up the screw holes
- Internal 7.2V Li-ion battery in the body. Come with 100V power adaptor to recharge full in 30 minutes
- Come with a screwdriver head set for various purposes
Compatible screws with included driver bits No.1 (+) Screwdriver
3mm~5mm Screws
No.2 (+) Screwdriver
2.0mm~2.6mm Screws
2mm Hex Wrench
3mm Hex screws, 2.6mm Cap screws
2.5mm Hex Wrench
3mm Cap screws
7mm Box Wrench
4mm Flange lock nuts
Specifications (Screwdriver) Motor
DC magnet motor
RPM
High 650rpm
Low 200rpm
Compatible
screws
Small screws ~M5
Wood screws ~3.8mm×45mm
Dimensions
Straight form Length: 279mm, Width: 43mm
Pistol form Length: 224mm, Width: 43mm,
Height: 141mm
Weight
0.55kg (including battery pack)
Specifications (Battery Pack) Battery
Lithium-Ion Battery
Capacity/Voltage
1.0Ah/DC7.2V
Specifications (Charger)
Input voltage
AC100V
Input frequency
50-60Hz
Input capacity
45VA
Output voltage/
Output current
DC7.2V/DC2.4A
Charging time
Approximately 30 minutes Include:
- Electronic Screwdriver set
- Screwdrivers head (5pcs)
- Battery (1pc)
- Charger (1pc)
Caution:
*The charger is for AC100V input only and with a 2 pins plug. Adaptor is needed if the voltage/socket of your country is different
Source: Tamiya
where to buy?
http://www.rcmart.com/catalog/rc-tool-tamiya-74089-electric-screwdriver-pt01-p-29744.html
1 - 1 of 1 Posts
