1 - 1 of 1 Posts
*Click the image to buy
Tamiya (#58341) TT-01 Mercedes-Benz C-Class
DTM 2004 Restock!
1/10th Scale Radio Control 4WD High Performance Racing Car
Tamiya presents the 1/10 scale R/C model of Frenchman Jean Alesi's No. 8 AMG Mercedes- Benz C-Class DTM 2004. The Mercedes C-Class comes with a fully finished body, with paint and markings pre-applied, and is mounted on the user-friendly TT-01 chassis.
FINISHED BODY
This R/C car is a replice of the Mercedes-Benz C-Class model driven by Jean Alesi in the German DTM Touring Car Championships. Body shell comes fully painted with all markings pre-applied. Electric powered assembly chassis features a shaft driven 4WD drive train for excelled cornering and smooth handling. Overall length: 459mm, Overall weight: 190mm, Overall height: 131mm, Weight: 990g
Not Include:
TUNE-UP!
RS-540 Sport-Tuned Motor
TT-01 Ball Bearing Set
CVA Mini Shock Unit Cylinder (4pcs)
TT-01 Aluminum Propeller Shaft
TT-01 Aluminum Racing Steering Set
TT-01 Carbon Upper FrameTamiya TEU-101BK (Forward / Reverse)
*Includes an electronic forward & reverse speed controller.
*Ready to assemble radio control model kit
*Front and rear double wishbone suspension
*Coil spring damped suspension system
*Racing tires and wheels
*High performance 540 type electric motor
*Highly detailed polycarbonate body shell
*Requires a 7.2V running battery and standard 2 chan. R/C unit (Not Included)
*Shaft driven 4WD system steadily transmits power from longitudinally mounted motor.
*Fewer number of parts, nylon resin drive shafts and wheel shafts realize easy assembly as well as weight savings.
*Fewer setting areas for easier control and setting
*Low placement of battery and R/C unit realizes balanced and crisp driving performance.
About the Mercedes C-Class
There were 4 differently colored AMG Mercedes C-Class cars competing in the 2004 German Touring Car Masters Championship (DTM-Deutsche Tourenwagen Meisterschaft). Former F-1 Driver Jean Alesi’s metallic silver No. 8 was noticeable by the strikingly large AMG logos on the bonnet and sides. Alesi put in a strong performance in his third season in the German DTM, coming in 7th in the drivers’ championship. Mercedes came in second in the manufacturers’ championship, missing first place to rival Audi by a mere 4 points.
About the Model
Accurately shaped polycarbonate body of the 2004 AMG Mercedes C-Class on the lightweight easy to assemble TT-01 chassis.
Pre-applied coloring and marking of Jean Alesi’s No. 8 car in the 2004 DTM.
4WD shaft driven bathtub chassis with 4-wheel independent double wishbone suspension and sealed front and rear differential gearbox.
Powered by a Type 540 motor.
Kit includes racing slick tires and electronic speed controller
Wide variety of grade-up parts available (sold separately) allowing the TT-01 to develop with your R/C experience and knowledge.
Where to buy?
http://www.rcmart.com/catalog/rc-tamiya-mercedesbenz-2004-tt01-wesc-58341-p-12489.html
1 - 1 of 1 Posts
