Actual trinity add: :thumbsup:
Trinity T-SPEC
Where Skill is More Important Than $$ Spent!
Tired of having to spend money you cannot afford to spend to try and stay competitive? With T-Spec it's your tuning and driving ability which decides who is first over the finish line, not how much money you have to spend.
Look for the new Trinity T-Spec program coming to a race track near you! The same chassis, motor, batteries, body and tires with no after-market parts or drilling, lightening and cutting makes racing as close and inexpensive as possible.
Features include: Spec Motor, Spec battery pack, T-Spec body, Shaft Drive, Aluminum Drive Shaft, Aluminum Drive Couplers, Ball Differentials, Pillow Ball Suspension, Adjustable Caster, Adjustable Camber, Adjustable Toe In/Out, Front & Rear Droop Screws, Ball Bearings, Threaded Body Oil Filled Shocks, Heat Sink Motor Clamp, Stick or Saddle Pack, Rear Sway Bar and Motor Heat Sink.
TRI90003 - $159.99 (Car Kit Only)
TRI90004 - $199.99 (Car Kit with Motor, Battery and Body)
