1 - 1 of 1 Posts
· Premium Member
Sweep Racing have released their new high traction type EXP-36E 1/10 on road rubber racing tire, which feature superior traction levels compared to the company’s successful Sweep ‘R’ and ‘QTS’ series tires. Using a new rubber compound to gain maximum traction, the diameter is in between the ‘R’ (65.5mm) and the ‘QTS’ (63.5mm), which is 64.5mm to work well on both carpet and asphalt surfaces. These tires, the first in their new EXP series, are designed for best use in track temperatures starting from 33 degrees celcius.
Source: Sweep Racing [sweepracing.com]
</img>
</img>
More...
1 - 1 of 1 Posts
