Howdy all
First time post here.
I got a great deal on a Yerf Dog Gocart for the Kids.
It has a 6.5 Hp Tecumseh, It had sat for a Year with old gas in it.
When I got it home I put some new gas in and the darn thing actually fired up. The Idle would surge from all most a stall to when the Gov would catch it and get her going again.
Well I rebuilt the Carb which has only and Idle Adjustment on it.
I think I cleaned out the Bowl pretty good and the Mainjet bolt on the bottom. Maybe I missed something. The Plastic tube in the carb above the Main jet I pulled and replaced the O rings, New gaskets, I didn't check Float level though.
I Think I might need to replace the Felt washers on the end of the Butterfly Rod. I'm not sure.
It still surges at Idle. But if you give it a little throttle it will rev up and slowly come down. Kinda like a Vacuum leak. I checked the plug and it was Black, So its not lean HAHA.
Any Ideas? am I on the right track?
Can you get any parts to make this thing Fully Adjustable?
There is one screw on the side that looks like a Low speed adjust but when you remove it , it looks more like a Jet than a Needle.
Thanks
Tom
Thanks
Tom
