1 - 1 of 1 Posts
· Premium Member
New from ST Racing Concepts are these pro-racing aluminium 1 degree rear toe-in hub carriers for Traxxas Slash/Stampede and VXL/Rustler VXL. CNC machined from high-quality aluminium material, these rear hub carriers hold the tight-tolerance for an accurate 1 deg. toe-in. A set-screw over the hinge-pin design secures the hinge-pin in the hub carriers and this design prevents wear from the hinge-pins on the hub carriers. Available in blue, gun metal, silver and red. STRC also now offers replacement components for their option parts line. Items such as their lock-nut style hinge-pins available in pairs separately, O-rings seals for the aluminium shock bodies, replacement high heat-treated front axles for thev17mm hex conversion kit, and upper shock mounts for the front and rear aluminum shock towers.
Source: STRC [teamstrc.com]
</img>
</img>
More...
1 - 1 of 1 Posts
