1 - 2 of 2 Posts
:wave:new carb. great spark, new plug, 85 lbs. of compression,flywheel key is good,carb is adjusted to spec. i tryed using an ignition tester the type that has the spark plug built in to a pump that simulates compression while spark is firing that was good.also tryed some carb spray that didnot help.
Good evening.The compression (85psi)is on the low side.100psi is usually considered the minimum for most two stroke motors.Have you pulled the muffler and checked for a stuck piston ring or heavy scoring of the piston or cylinder wall?If the piston ring is stuck,you have a good chance of freeing it up and increasing compression.Make sure the bolts that hold the cylinder to the crankcase are tight also.
1 - 2 of 2 Posts
